I have just overhauled the engine with new main bearings ,rod bearings, new pistons 45 over. Everything has gone great thus far. My problem is my oil pressure is low. Cold around 21 psi on a numeric gauge. I didn't
do anything to oil pump during rebuild other than disassemble and clean. My pump had two washers in the relief valve. I have added 3 more and only raised pressure to 25psi. My manual says I need a working
pressure of 30 psi. Whats my next step in correcting the low pressure?
