4320 PTO lever chatter
mlauk
I have a 1972, JD 4320 and the PTO started slipping while shredding. I noticed the PTO had a little chatter on the lever when engaging with no implements attached. Could this be the hydraulics or the PTO clutch?
Likely, your PTO clutch is pooched,and needs a complete rebuild, then be sure the PTO valve linkage is set up as detailed in the SM.
NOT the best setup the GREEN Co. ever had, and it takes some serious GREEN to bring it back when it fails.
