So here is my issue I had a button clutch and while my tractor was split I thought I would change it out for a standard clutch disk. I had the JD dealer adjust the clutch, took the whole thing home and installed it. Put the tractor back together and noticed that that clutch pedal was in the same position as before I took everything apart on the bottom of the adjustment slot. But I started the tractor and it would not shift into any gears, shut off the tractor and put it in gear and started it and with the clutch pedal pushed in it took off. Had a friend look and thought maybe the fingers needed to be closer so we adjusted them and moved them so that the bolt was at the top of the adjustment slot. Started the tractor again same result. the PTO engages and disengages fine, you can see the springs move when pushing in the clutch. Wondering do I need to put my button disk back in? Any ideas Please help
thank you
thank you
