7400 Steering Hoses
Hotflashjr
Location
Western MA
The new to me 7400 blew one steering hose this weekend. Another one had been rubbing on a fender and had no rubber left. I am replacing all 4 lines, O-rings, 1 tee fitting. Any thing I should know? This is the hydrostatic steering on this tractor. Does it need to be bled once back together or will it work air bubbles out on its own?
Just run the wheel from lock to lock a few times to push any trapped air out.
Those are a nice tractor.
Replaced all hoses, O-rings and tee fittings the other day. Went to turn the steering wheel and nothing... Scared me for a minute then after a few more turns everything worked great. No need to bleed anything, no leaks on the first try.
