John Deere 530 sediment bowl
JimWA
We have a 530 that is getting gas in the crankcase. The sediment bowl is oily. What is the recommended way to fix this? Buy a new sediment bowl and not use the low oil pressure feature? Or what options do we have?
Diaphragm is leaking. Part #A4983R, 2 used. Under $10 each through the John Deere dealer.
Might as well replace the sealing washer, as well. A4978R, under $2 from the dealer.
Shouldn't be any freight if you have them ordering on a stock order.
I think some of the restoration supply places may have them available in a kit????
