520 platform removal
55 50 Ron
What procedure do you use to remove the platform? Does it need to have the battery box removed first? Want to get the platform off so I can replace the battery cable to the starter.
Seems that no matter which way the platform is moved, it is bumping something to prevent removal without taking a lot of other items out of the way.
Thanks
Seat and battery box off, is the only way I have been able to do it. It hits PTO lever, or brake petals, or battery box, otherwise.
I have change a few cables out and never removed the platform only rough part is getting the cable secure behind the flywheel. Try shaping/bending the cable this will help it laid in place.
