i want a pic of G flywheel
dieselade
Location
indiana
on the shaft. also want a pic of the end of crank drilled and a plate and bolt installed.
I missed the tractor shows this summer to check on this.
Here's one:
I've got one like that on mine except it is a little bigger so I could put bolts in the 2 flywheel holes as well as the crank. I shimmed under it so the flywheel can't go either way.
