JD2030 Oil Pressure Sending Unit Location
Plowery
New User
Wondering if somebody knew where the oil pressure sending unit is on a JD 2030. I see one behind and above the starter on the right hand side (if you in the drivers seat) and another one that is on the side of the block on the left had side. Both are broken so can tell anything about them. Left hand side is going to be a little hard to remove so kind of waiting to see what it is before I start.
IIRC, oil sender is at right rear of engine, and heat gauge is mechanical, so if you're seeing what appears to be a second sender it MAY just be the remains of the mech heat gauge's thermostatic bulb assembly.
Just screw a mechanical gauge in the spot by the starter. You should be able to see
it easily from the seat. Ben
Finally figured out what that was on the left side of my JD 2030 engine block. I was looking at a JD 2020 on You Tube and noticed it. Suspense huh?
It was a water valve like in a radiator. Seems kind of high on the engine block to me.
