SGC Roof Replacement
2510Paul
I have to replace the roof on a 4055 SGC. There are about 10 rivets holding various hardware to the roof. Does anyone know what tool is used to install the rivets?
I have to look more closely but I am assuming they are a Pop Rivet, but I have to confirm. Maybe someone on here knows? I have a smaller Pop Rivet tool but I am sure it would not do those.
Thanks.
Paul
Specification
Weight:?
0.00?LBS??0.00?Kg
Rivet Diameter
0.188 IN
Rivet Length
0.664 IN
Head Diameter
0.625 IN
Mandrel Diameter
0.114 IN
Head Thickness
0.070 IN
Material Thickness
0.500 IN
Mandrel Material
STEEL
Rivet Material
ALUM
Here's the spec's on the Rivet.
Paul
I put some in with a regular rivet gun that had 2 size bits. The Deere rivets are pretty much same as other rivets with a big flange, just get the right length. What I know now, I would have removed whole underroof and resealed with that black sticky cord, some people call it dum-dum. Of course if you silicone it down and pop rivet it will stay stuck and waterproof if the rivets corrode. When the aluminum rivets get corroded they give it up. Its a '90 2555, dont know if they changed rivets down the line.
Thanks guys for the responses. Yes, once I looked at the actual size of the rivet I realized the tool I have may work or at worst I may have to go to the hardware store and buy a $20 rivet tool. The size of the head was throwing me off as you said. Sorry it was such a wimpy question. :) Paul
