Powr Trol Problems remote cylinder
pjbofmn
I have a 1951 John Deere B with Powr Trol and the remote cylinder will not retracted. Put the cylinder on my Oliver 880 and the cylinder works fine. I"ve pulled out the plugs ok. check valves ok.as far as I can tell. took the top cover off by removing the seat. Not sure but looks ok. full of fluid. help please would be greatly appreciated
Sounds like you have the wrong plugs and you are on 1 way cyl. but need 2 way plugs . check owners manual for correct plugs .
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]I don't know what one way and two way plugs look like[/i:654c4848f0][/b:654c4848f0]</font>"
Take a look at the [b:654c4848f0]POWR-TROL VALVE HOUSING[/b:654c4848f0] diagram below.
a168526.jpg" width="650"
Note the plug (Key) 9 and the oil coupling (Key 25).
Take a look at the photo below of the plug, sometimes referred to as a "dummy plug".
a168527.jpg" width="650"
Note that the plug has a solid, closed end.
The plugs are installed in the Powr-Trol housing when a remote cylinder is not in use.
a168531.jpg" width="650"
Take a look at the photo below of the oil coupling.
a168528.jpg" width="650"
Note that the oil coupling has an open end.
Take a look at the photo below of how the oil flows through the oil coupling.
a168529.jpg" width="650"
If the remote cylinder has one hydraulic hose for both supply and return, then connect the hydraulic hose to the bottom oil coupling.
a168530.jpg" width="650"
If the remote cylinder has two hydraulic hoses, one for supply and one for return, then connect the supply hose to the bottom oil coupling and the return hose to the top oil coupling.
Hope this helps.
I have both plugs with open ends in both back ports. With the return on top and supply on bottom from the right side ports. when I push the lever forward the cylinder goes out but when I pull it back it doesn't do anything , I can push it in a little by hand thou. but both plug with the hole from the check valve closer to the edge then the ones in the picture
"[b:654c4848f0][i:654c4848f0]<font color="#6699ff">plug (30 key-36 key) out not sure what it is.[/i:654c4848f0][/b:654c4848f0]</font>"
Those are parts for both the upper and lower check valves.
Take a look at the diagram below.
a168538.jpg" width="650"
Note that the upper check valve is connected to the upper oil coupling.
The upper oil coupling is connected to the hydraulic hose return from the remote cylinder.
Hope this helps.
in order to have a double acting cylinder u need the plugs with hoses in the rear not out of right hand side. been there done that and had same problem.
