4010 puller
Hi guys tearing down a used 6081 engine to rebuild and had a couple questions. Took front gear cover off engine, water pump is in cover, looks like impeller is going to need pulled off before removing snap ring to remove pump. Looks like impeller puller tool is 400 bucks, any other way to remove it without this tool for one time use?
I've also been studying the jd head bolt situation, looks like there are several sets of head bolts for 466,7.6,8.1. Some have said the bolts can be reused some say replace. My bolts are marked special. Should I reuse them and should I put this style back in?
Thanks
Thanks
