4230 no crank issues
Picked my 4230 up from the shop and it started fine, but when i got it home it wouldnt start off the key plugged the charger in still nothing the only way to get it to start is to jump it off the solenoid. The tractor will start in gear which is a huge issue but i cant fix that till i can get it to run off the key. Ive replaced both solenoids one on the starter and one on the firewall and still nothing ive even jumped across the neutral safety swicth and still nothing. When i turn the key the voltmeter and gauges act normal but when i go to start it i get nothing no clicks nothing. kind of lost here and dont want to take it back to the shop thanks for the help!
Did the shop do any work under the dash? Maybe wire came off of the key
switch for the starting.
no all the work was done outside when I was at the shop it started off the key but when I got back to the house it wouldn't start off the key
My son had a 4230 some years back, had lot of no start problems with it, seems like there was a relay under left side of dash that could give a problem also. If I remember correctly, it had to have 12.1 volts to close. Been along time, hope this is correct.
(quoted from post at 21:59:43 08/08/17)
Ive got a volt meter just not sure where to start
Start at the key switch, make sure there is power to the switch and to the start terminal when turned to start, then chase it to the next point until you find the problem.
