3020 front wheel bearings
It seems that the parts store where I have been getting Timken bearings can no longer get them for certain applications. One of those is a set of 3020 front wheel bearings. Does anyone have a source of good quality bearings? The last time I tried my local deere dealer the inner was from china and the outer was from mexico and neither seemed to be too good quality. Thanks for any help. Lee
If you have the Timken numbers, check ebay. Most likely you can find NOS USA-made bearings there, with a little searching.
On the other hand, imported bearings would have to be REALLY bad not to be good enough for front hub bearings on a little 3020, IMHO.
Thanks Bob, I have a front end loader on it. The ones from deere only lasted about a year or so. The original bearings on the other side are still good while getting the same treatment. Lee
Can you find KOYO bearings ? They use Timken steel to make them , but funny thing is in tests Timken research had done in the past the Koyo's tested better ! But this has been a few years back and things do change.
