jbsundberg
New User
Question on the JD500 hydraulic pump. The backhoe came with a long section of rigged plastic tubinge from the hydraulic pump bleed port (secured w/hose clamp) routed to the top of the hydraulic filler tube (under operator seat). Naturally the dipstick only sits loose due to the tubing with a white sock over the whole setup to keep dirt out. It works in that the overflow fluid from the pump gets back into the tranny - but would like to clean up and get it right. I've purchased the bleed tube kit (long black tubing with flare type fittings on each end) from the JD parts diagram but nowhere can I find in the parts manual or diagrams where the other end connects into the transmission so I can clean up the tubing mess? Our local John Deere dealership (Nortrax) does not know - can anyone point me to where this connection in the transmission would be? Thanks.
