John Deere 4450 Quad Range problem
JohnDeereR
New User
Rebuilt transmission with all new bearings,gears,shift forks,and shift cams. Set up by the book. Everything works good except shift from B range back to A range is really difficult. Any help would be greatly appreciated.
Just a thought , make sure the clutch is fully releasing . Then shift it by hand to make sure the shift rods are adjusted right , Might need a helper in the cab to hold gear shift in place . If the clutch was taken apart was it adjusted with the special tool ? Just a few thoughts hope this helps .
New permaclutch discs were installed with John Deere tooling. Actually shifts harder with engine not running. It shifts better when you can let tractor roll just a little, will sometimes then slide right in. Thanks everyone.
Shifts fine from A to B. All ranges,all gears, and park operate fine except B to A. Seems to depend on how gears are lined up when tractor is stopped for shift. Sometimes it shifts from B to A fine. Thanks.
