POPGUN
Ref Governor: Did as per your instructions. The Governor itself is now doing its thing as it should. Now it is a matter of adjusting the carburetor throttle rod. It looks like PO used the bend it here and bend it there adj method and the threaded end needs to have the threads chased, but they gave me enough to know the Governor itself is working. Let ya know if I get it or if I need more help. Thanks
Great!
I've only once had a torch fail to make that adjustable end not come free!
All things working, they're pretty sensitive. Don't get it too short or it will be slow to slow down to idle & jumpy if trying to parade at a slow engine speed with it in a high gear!
Thanks for reply!
