67 4020 db injection pump
gidtex
Does anyone used a torx plus 45 to remove cam screw on db pump.i know some poeple grind a torx 45 to fit.torx plus look simliar to spline bit.bristol bit
If you are going to play IP mechanic, do yourself a favor and get the correct Stanadyne tools. Should be able to find them reasonably on the 'net.
Besides having the correct "bit" having the "support bushing" will often save some heartache.
Stanadyne part numbers
