Hydraulic Screen
nh8260
Just wondering if you guys knew a way to remove the screen in the hydraulic system on my 2120 JD. Changing the filter I normally lose around a gallon of oil, just curious if parking it on a slope or the side of a hill would work better for the screen removal, trying to keep from losing as much oil as I can.
You will need to drain oil to check/clean screen or insert nozzle of a running shop vacuum into hyd filler hole with remainder of filler hole blocked off with a towel.
