4040 overheating update
I finally got to look at it today and found the water pump pulley was misaligned. This wore bad enough to let the belt slip when it gets hot. I have to replace all the pulleys though. How hard is it to replace the lower pulley balancer setup? Thanks for the help
Try a new belt. You would be surprised how much thinner the old belt will be .I would suspect the water pump bearing needs replaced .
