Well the starter didn't solve the problem, the lug on the switch was not isolated . When I re-installed the starter and tested the system, No drain. The I attached the rest of the harness, No drain. Pulled the lights on and you could see the amps being used, shut the lights off and no drain. I decided I would start it to see if it was charging and it was. I thought all good. then I shut it down and I figured I better check again. Well low and behold the amp draw was 23.xxx I went to the generator and the regulator was steaming hot. I guess I need a new regulator???? I didn't have time to open it up but that is what I am going to do first. Any advise appreciated.
