Jd 730 how much power steering oil? And part numbers?
I'm at work and need to order some stuff and don't have the book on me. How much power steering oil does a jd 730 diesel take? I had a line crack and lost all my oil. I assume it's like the other jd and is recommended to only run deer power steering oil? Also does anyone have a part Humber for the fuel filters?
Thanks in advance
IIRC, between 3 and 4 quarts, IF completely dry, which it obviously isn't. Yes, use the good 'ole DEERE 2-cylinder PS oil, #AF2235R.
The fuel filters are currently #AR44077, if no gaskets with them, gasket is #R1021R, be sure to get EVERY BIT of the old ones dug out of the grooves in the filter "head".
