jd 2020 hydralic lines
jdgrayt
New User
I have a johndeere with a collar shift. I had to split the tractor to replace the clutch disk. I disconnected the two hydraulic lines at the clutch housing, one line goes to the cooler the other goes to the pump. Now I am not sure which line goes into what hole at the clutch housing. what line goes toward the center of the tractor and what line goes to the outside?
The one I marked in red goes to the inside with the check valve.
