Jethro Lilley
I have a rebuilt DBGFC 331-1AJ pump from the local dealer that stopped pumping 6 weeks out of warranty. The first time I noticed a problem was the end of June when it wouldn't start but a shot of ether cranked it up and it ran a 6ft Bush Hog Squealer all day just fine. It started several times all day for our July 4th parade (pulled a wagon-load of Lilleys and won 1st prize) and then it was parked. Last week it would not start and ether did no good. No smoke from the exhaust. I checked the fuel flow to the injector pump with good steady fuel flow. Cracked open the 3 injector lines and no fuel. Drained the coolant, took off the bottom hose and removed the inspection cap to see if the nut was tight and the shaft was turning... it was. I'm at my wits end.
Have I missed something? I really don't want to give Mother Deere another 1500 bucks for another rebuilt pump if it isn't absolutely necessary.
