Something is going on with the starting system on my 51 B. Sometimes you push the switch down, and the starter simply spins freely without grabbing the crankshaft. It can do this a few times before it will actually catch. When it does catch, it will spin the engine a few times before it makes a bit of a grinding noise losing the crank/overrunning clutch on bendix kicks in. This system has been converted to 12V, so it spins fairly fast.
I took the starter out, and the gear on the end of the starter seems to look okay. It will slide in and out okay on the shaft when the switch is depressed. I did notice some irregular wear on the teeth of the flywheel. One roughly a quarter of the perimeter of the flywheel, the first 1/4" of teeth are worn/ground a bit. I assumed this was not a huge deal, because it looks like if/when the starter is fully engaging the flywheel you have a good inch or so of gear engagement.
My question is the following: is there anyway to adjust the amount of engagement of the starter gear? Would there be any reason I would not be getting proper engagement? Is this wear on the flywheel unacceptable and causing the problem?
Please let me know your thoughts.
