Greetings! I had posted this inquiry in tractor talk was suggested to post for John Deere experts! 4020 serial #76000. Oil in the radiator. I am a truck/diesel mechanic so am aware of oil cooler and etc. I was told the head gasket could cause oil in coolant? The head gasket is defintely leaking and we are going after it too. Can the oil for rockers leak to the coolant at head gasket on a 4020? also could it be the gasket under cooler leaking as It appears that could also cause issue? Cooler is a pretty robust design but then again it has been around for a while! Thanks for input. Oh yeah is the Y T head gasket set a good choice?
