Glen D Anderson
Hello,
Several questions for those who have installed &/or who are running turbo chargers on their 4020 diesels:
1/ Comp. ratio - Anyone running a turbo with aftermarket "high compression" pistons? (ex. Reliance's 17.65:1 pistons)
2/ Boost - What numbers are you seeing? What turbo are you running? Any other mods. done to the unit like the inj. pump turned up, exhaust, etc.?
3/ Fuel consumption - What are your numbers? Please provide details if possible such as load conditions, etc.
FYI, the first 2 questions are simply pointed towards the compatibility of boost & elevated compression on the 4020.
Regarding question #3, I was looking at the threads with Tim S's impressive turbo upgrade & it has me wondering if there would be enough of an increase in economy to pay for the parts / machining & eventually save money. Of course this all assuming that you could perform the mod. yourself(no labor charges), you are not asking more out the tractor than what it's capable of, & that you are using the tractor often / burning enough fuel in the first place.
Thanks in advance,
Glen
Thanks in advance,
Glen
