2020 load shaft
mb58
Before sliding the load shaft through the tractor, does the white "seal" go in the groove first and then the oring fit on top of it or does the oring sit beside the seal down in the groove?
The o-ring goes in the grove first with the white ring inside of it. The white ring rides the shaft while the O-rings seals between the white ring and bushing.
Also put the white ring in a cup of HOT water before trying to install it. The water will soften it up. You have to fold the white ring in on it's self to install it. With it warm and flexible it is easy to do. Without warming it up they can break when you fold them to install them.
