JD720 PTO Clutch Oil Problem
chas036
My pto will not stop turning even when disengaged. When I drained my pto clutch on my 720, the oil looks like it and smells like 90wt gear oil. I assume there is an oil seal between the pto assembly and the gearbox that is probably bad and allowing gear oil to pass into the pto assembly. How difficult is it to replace this seal, and does the whole pto clutch assembly need to be disassembled to do it?
have to take the rockshaft housing off of the axle housing. then there is 4 3/8 bolts that hold on the pto pump to the rock shaft housing, remove them and pry off the pump housing, there is a couple dowel pins there that will probably hang up. i usually replace the bushing and it takes 2 seals to replace the one old seal. install a lip facing each way with the new seals.
Steiners created a video that goes through the entire process step by step. It's available on the internet.
