2130 hydraulic shutter
hi i just bought 1976 2130 and runs good trans is good with new tires but hydraulic shutter or stop. i will change the filter but i read there is a sump screen somewhere to check. where is this screen and a [icture would be great.
Welcome to YT
One needs to drain hyd oil or put the nozzle of a running shop vacuum in hyd filler opening with remainder of opening blocked off with a shop towel to check screen(key 30). Also check hyd filter relief valve(key 24-26) to be sure it isn't stuck in trans housing
(quoted from post at 06:32:03 06/24/17)
YEPPER
changed filter and hydraulic oil and cleaned screen. it works now. screen was plugged solid and oil was pretty bad. i might do this again in a week again. front end loader has a very tiny shudder but hardly noticeable. before i changed oil i drove it around for 20 minutes and hydrauics quit all together. i just need a lawn tractor and it is great . hope it keeps running. motor purrs like a kitten thank you for the help
You're welcome. Thanks for update & congratulations. Sometimes the solutions to problems are simple. What did foreign material on screen resemble?
like purple thick jelly and the oil was dirty light brown to grey now i need to fix the throttle on the dash is siezed but the foot throttle pedal worksi sprayed hand throttle beside batteries with nut cracker but still siezed.
Where is the loader supply oil and return oil plumbed to ? The rear SCV or direct to a pressure line and return to a ported filter cover . The nasty oil must be thoughly gotten rid of from everywhere asap.
