Mac AR
- Location
- The Hills of Home - The Ozarks
Hey guys,
I have a 1950 B with the power-trol on it. Have used it before some with a front cultivator, and last night decided to put a 3 point conversion on it. Well, long story short I let the rockshaft arm bind on the the lift arm while raising, and the bottom dummy plug went flying out across the shop. I replaced it, added some more oil, and fixed the binding issue. Now, here's the problem - seems like the lift is only coming up in stages, or steps. Also seems weak, will not lift me (225#) past a certain point in slow raise, will lift me to the top in fast raise position, but wants to sink down a few inches then hold. Also, the drop is very fast, I have little to nothing on slow lower. I have ordered SM-2022 so if I need to take things apart and replace seals, etc. I can. I'm hoping that all I've done is blown and o-ring or something, but I'd be interested to know what you all think.
Thanks in advance, Mac
