6200 PTO leaking
XL cid A
I've got a 6200 that's leaking out the PTO I put a new seal in but this is coming out where the PTO stub shaft goes in. It has the duel speed PTO. There's a retainer oring and piston behind the shat when you take it out. Too change the oring that I think is leaking does anyone know can you get the retainer out and change the oring from the front hole where the stub shaft goes in.
Reference number 25 and 25
Check you got the right seal, one is metric, one is imperial and to the eye they look the same, but they are not.hardly any difference in size, check the size markings on your original seal. If I go out to fix one I always take both seals with me-no serial number break to tell.
