Rock Shaft Leaking Down
What causes my Rock Shaft to leak down sometimes? Other times it is fine. It is a Power-trol on my 1952 model A. It does not lose any oil. This started about two months ago when it would not hold the mower up any more. Then last week it started working fine again. I figure I am ?living on borrowed time?, and will need to work on it next winter, but I was just wondering what I should be looking for when I tear into it.
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]What causes my Rock Shaft to leak down sometimes?[/i:654c4848f0][/b:654c4848f0]</font>"
Reviewed the [b:654c4848f0]Hydraulic Equipment SERVICE MANUAL John Deere Waterloo Works SM-2011 (Dec-52) Section 70 TROUBLESHOOTING Group 5 POWR-TROL[/b:654c4848f0] section on page 70-5-1.
<font color="#ff0000">[b:654c4848f0]WILL NOT STAY IN RAISED POSITION[/b:654c4848f0]</font>
<font color="#ff0000">[b:654c4848f0][i:654c4848f0]O-rings leaking at lower hose adaptor.[/i:654c4848f0][/b:654c4848f0]</font>
a163057.jpg" width="650"
Note the O-ring packing (Key 1) and O-ring packing (Key 2).
<font color="#ff0000">[b:654c4848f0][i:654c4848f0]Check valves leaking.[/i:654c4848f0][/b:654c4848f0]</font>
a163058.jpg" width="650"
Note the outer check valve (Key 38) and inner check valve (Key 39).
<font color="#ff0000">[b:654c4848f0][i:654c4848f0]Piston ring leaking.[/i:654c4848f0][/b:654c4848f0]</font>
a163059.jpg" width="650"
Note the ?U? cup packing (Key 18).
[b:654c4848f0][i:654c4848f0]<font color="#ff0000">Sand hole in cylinder casting.[/i:654c4848f0][/b:654c4848f0]</font>
a163060.jpg" width="650"
Note the cylinder (Key 4).
<font color="#ff0000">[b:654c4848f0][i:654c4848f0]Gasket leaking between end cap and cylinder housing.[/i:654c4848f0][/b:654c4848f0]</font>
a163066.jpg" width="650"
Note the ?O? ring packing (Key 5) [b:654c4848f0]A 3606 R[/b:654c4848f0].
Hope this helps.
James - Thanks for your help. Because it comes and goes, I am thinking the 'U' cup packing on the top of the piston, but I hand not thought about the check valves. I am wondering if I have dirt in my system. I might drain and refill with new oil.
