JD 665 zero turn mower
DTK
We have z665 zero turn. Do any of you notice a burn streak in the grass in the center of the mowing swath? We haven't noticed it other years but maybe it happens when mowing lawn on a hot day during dry times. Any thoughts? Thanks , DTK.
DTK,
Is your exhaust blowing down towards the ground. I have seen this happen with some cub cadet models in years past.I know it seems hard to believe.
Mar2290
Is your machine under 120000 serial number? If so, there may be a recall on that machine for complaints of brown/burned grass. The solution is to replace muffler and heat shield. You might want to talk to your local Deere dealer and see what they can do for you.
