G thrust bearing
MSD
Want to replace the thrust bearing on the steering shaft of my G. Deere part number is JD7684R which crosses to ND #E30210A or Fafnir 7210FT. The Fafnir #'s I have found are 7210W, 7210 WN and just 7210. Looking on Ebay at different pictures of the different numbers they appear to have different cages and some even have less balls. The one's I am looking at are old stock Made in The USA printed on the bearing. What #'s have any of you used? Sharps is out of them currently.
There is a guy named Brian in Crooks S.D. that messes around a little with those old G's, he may be able to help you out. Not sure if he posts on here or not. Can't seem to remember his contact info though.
You might try National Bearing inNew Jersey. They have lots of hard to find bearings at very reasonable prices. (908) 722-8100
