happy gilmore
Good Morning! My son recently purchased a 1952 G john deere. Had a cracked fuel bowl, found a replacement bowl and had the neighbor put a carburetor kit in. Finally got it to start yesterday, but does not run the best. ran it out of fuel, put new back in. Didn't want to start. Ended up pull starting it. Still misses, pops and farts. Can some one give me a base point where to adjust the idle and power needle settings. I just put a set of autolite 3116 plugs in. This tractor has the high compression pistons in it. Would it run better on tractor fuel? Ignition? Any help will be most appreciated!!! THANK YOU-Happy
