JD 4320 load shaft
fordfx413
Where is the best place to get a load shaft, bushings, seals? JD, A&I? Also saw a link on here for boling machine shop. Thanks
Have you checked bushings for wear? Way back when I was a JD dealer service manager I was taught only to replace L/D bushings if they were worn enough to justify replacement. My 4255 has over 11,400 hrs on original L/D bushings.
Like Jim says...in 20 years as a JD tech I think I only once replaced load shaft bushings in a tractor. Shaft and seals and I about always replace the shaft 'cause I hate doing a job twice!
Load shaft seals/bushings go bad because there is too much side play on the shaft, does not help to have the arms banging back and forth.
