JD 401 industrial PTO shaft
37chief
Location
California
I can't find the part number for the PTO shaft on my 401 B Industrial. A few Ag tractors I believe are the same. I can find the PTO clutch in my parts book, but not the shaft. Any help appreciated. Stan
http://jdpc.deere.com/pimages/T699/T69924_________UN01JAN94.gifGEARS AND SHAFTS
(CONTINUOUS 540 RPM REAR PTO)
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 T22128 BUSHING 1
2 T22127 BUSHING 1
3 AT23224 SHAFT 1
4 M2353T SNAP RING 4 - 339686
5 T22214 GEAR 1 540 RPM (21 AND 73 TEETH)
6 14H812 NUT 4 3/8"
7 R30958 LOCK PLATE 4
8 T22234 BEARING HOUSING W/O BEARING 1
9 T21997 GASKET 1
10 R26656 WASHER 1
11 JD8877 NEEDLE BEARING 1
12A R47249 SHAFT 1 - 339686 REAR
12B R69509 SHAFT 1 339687 - (A) REAR
13 40M7044 SNAP RING 1 - 339686 (SUB FOR R47513)
14 JD9344 BALL BEARING 1 - 339686
15 AL56820 SEAL 1 (A) (SUB FOR T22069)
16 T22080 GASKET 1 - 339686
17A R47514 BEARING HOUSING W/O BEARING 1 - 339686 REAR
17B R69512 BEARING HOUSING W/O BEARING 1 339687 - (A) REAR
18 12H301 LOCK WASHER 3 1/2"
19 19H2993 CAP SCREW 3 1/2" X 1-1/2"
20 R27329 SCREW 2
21 ........ SHIM AR 339687 - (B) (B) 0.13 MM (.005") ( R69513 NOT AVAILABLE)
........ SHIM AR 339687 - (B) (B) 0.13 MM (.005") ( R69514 NOT AVAILABLE)
........ SHIM AR 339687 - (B) (B) 0.25 MM (.010") ( R69515 NOT AVAILABLE)
........ SHIM AR 339687 - (B) (B) 0.51 MM (.020") ( R69516 NOT AVAILABLE)
22 JD9125 BEARING CUP 2 339687 - (A)
23 JD9065 BEARING CONE 2 339687 - (A)
24 R69510 SPACER 2 339687 - (A)
25 R69511 BUSHING 1 - 339686 (A)
.. AR93928 KIT 1 FIELD SERVICE, SINGLE 540 RPM PTO THRUST CAPACITY
(A) KIT LISTED BELOW CONTAINS ALL PARTS IDENTIFIED BY (A):
(B) AT146240 KIT, SHIM
37chief
Does your 401 have continuous running(dual-stage clutch) or hyd ind pto(control lever between gear shift levers)? If your tractor has dual-stage clutch then pto shaft(key 12) is as follows.
R47249 Shaft - ADD 385.00 USD
JD did offer an improvement shaft kit(AR93928) with tapered roller brgs in lieu of ball brg but it is NLA
