3010 clutch
Olliejunkie
I started my 3010 pushed in the clutch and felt a little pop. Now I have no clutch. Guess the first step is to look at linkage and pull cover off this weekend. Any ideas on what might of slipped or broke. Hope I don't have to tear to deep.
There's a bolt that allows you to adjust the
travel of the clutch petal before it engages
the clutch. Under the left hand side of the
platform. The petal may have slipped loose.
Hopefully that is all it is.
It does look rusty around the nut like it has been moving. Guess I will have to go look or I will think about it all night.
(quoted from post at 03:27:08 06/10/17)
Sounds as if a tractor split with a R&R of clutch assembly is on the horizon
I'm afraid your right but I hope you're wrong. I'm sure something is broke but I have never had any clutch troubles.
(quoted from post at 10:56:57 06/10/17)
My guess is a pressure plate bolt that goes through a lever broke
Maybe I was tired and flashlight was dim. Will try to get a better look soon.
(quoted from post at 12:02:44 06/10/17)
After looking at some pics I don't think the pressure plate fingers slipped. Looks like some go in the groove and the others in front???
When I get home I will have a closer look. I can start the tractor in gear and it still moves so I think something slipped.
Sometimes I'm a little slow. Got to thinking maybe disc is froze so started in gear, put the clutch in and started jabbing brakes. Broke free 2 nd of 3 Rd try. Only had been sitting a few weeks. Thanks for all your input.
Clutch is out of adjustment so I think it's going to be on light duty. I probably have 10 Oliver's but the 3010 is the go to tractor.
