This message is a reply to an archived post by John T on October 19, 2012 at 17:28:17.
The original subject was "Re: 3010 Generator Light".
Thanks to your helpful tips n tricks the H is charging on all the original components (well you know)! First time since it's been here at the ranch and that's near twenty years. What I had been missing is that the field terminal goes to GROUND. Once I understood that, I went inside the 4 position switch and ran a ground to the battery from the lower end of the field resister. Done! Anyone know the ohms value of that field resister? mine or the low charge switch position is toast but the high position works, Woot woot! Suffused with success, I even got the original headlights glowing. Most of the wiring is still original also.
Pic is from about ten years ago when my father in law still came out to cut the pastures, I do it now and even moved all the way up to a drawbar mount mower!
No beauty queen, she's a working gal.
