JD 7520 4 wheel drive transmission
rdhRDH
Have to rebuild top shaft on 7520, anywhere to get complete shaft or will any other tractor shaft fit it
You will need to get the replacement parts from Deere, and they are pricy,,if you did get all the parts for a complete shaft, shaft and all you would be looking at near $3,000,,you most likely need the 2 drums,drive collar, bearings and sychro clutches, and look at the trans pump while it's out
R36678 Drum - DRUM,SYCHRONIZER ADD 509.19 USD 1,018.38 USD
RE37105 Disk - DISK,SYNCHRONIZER WITH FACING ADD 24.78 USD 49.56 USD
R36677 Washer - PLATE,SYNCHRONIZER ADD 28.37 USD 56.74 USD
R35457 Shift Collar - COLLAR,LOW AND HIGH RANGE SYNC DR View/Update 375.94 USD 375.94 USD
JD7232 Bearing Cone - CONE,TAPER ROLLER BEARING ADD 26.72 USD 26.72 USD
JD8291 Bearing Cup - CUP,TAPER ROLLER BEARING ADD 15.15 USD 15.15 USD
JD8907 Bearing Cone - CONE,BEARING ADD 37.75 USD 37.75 USD
JD8240 Bearing Cup - BEARING ,CUP ADD 21.49 USD
