Here is a test for the JD guys
David G
The steering is sticking on my 130, a split will be required to correct it, who knows what this involves?
Shouldn't be much of a problem. You won't need a heavy duty jack or a BFH. Google Samuelson's in Dyersville if you need any parts.
Good luck,
Stan
You need to call Deere and order the operaters,parts and a service manual.(BuickandDeere will post the link soon).LOL You will most likely have to do a split but it should be an easy split. Those tractors require a special splitting stands as they split side to side not front and back like most other Deere tractors. Enjoy and thanks for the morning wake up. It took the brain a few moments to think this one. Tom
