Before I took apart my power steering on my 720, I measured the clearance of the steering gear and it was .020 which was within spec. I am reassembling the unit and I tightened the steering gear to as much as I can with my torque wrench which only goes to 150 lbs. No matter how much more I try to pull, I can't get the gap to shorten. Right now I have almost about an 1/8 gap between the gear and the shim. My question is, if I put a long pipe on my wrench to get more leverage, will this help shorten the gap, or have I reached the limit on how far the gear will travel? I am afraid if I put to much torque on that bolt, I will break it off.
