I checked mine and the number is 92598 so both are a little ways off from each other. My info comes from an article on the 55 done by JR Hobbs from Green Magazine. I don't know if you call Green Magazine and see if they will print you a copy or just look on ebay. That is were I got mine. The issue was September 1995. Also, might want to check into Two Cylinder magazine to see if they did anything on the 55. I prefer articles from JR but he has passed on now. Also our 55 came from Dave Preuhs around Le Center Minnesota. I think he specialized in Hart Parrs tractors. Last I knew he was using a JD 105 maybe a corn special as his primary combine. I watched your video on the 55 and honestly it doesn't look that bad for sitting outside in MN. There is a lot more rusting weather over there then here in Montana.
