Danfitz55
I am have a 146 loader that i want to put on my 2640. The tractor only has one remote so I would like to run it through a joystick or control vavle and not through the remotes. I am not sure of the right way to go about this any help would be appreciated. Thank you
Loader valve must be supplied via the supply line to the remote and returned through a inlet on the ported Trans oil filter canister. Get a loader mounting manual, there are several variations on the hydraulic plumbing, side plates may need some modification, and on some models, the starter housing may need to be rotated. Ben
This is the way JD engineers elected to attach ind hyd valve to a JD utility tractor for a model 146 FEL. Fitting(key 5) attaches to rear of pressure control valve located on RH side by hyd filter housing.
