John Deere D/ 70 Diesel
When my neighbour receives the TOP end Gaskets ( I shall be involved installing the HEAD), I'll record the VALVE NUMBERS and report back:
Bob..
Take a look at the [b:654c4848f0]CYLINDER HEAD. VALVES. AMD TAPPETT COVER[/b:654c4848f0] diagram for the Model 70 Diesel.
a160715.jpg" width="650"
Note the intake valve (Key 21) part no. [b:654c4848f0]R 57 R[/b:654c4848f0].
Take a look at the [b:654c4848f0]VALVE ASSEMBLY[/b:654c4848f0] diagram for the Model D Styled.
a160716.jpg" width="650"
Note the intake valve (Key 16) part no. [b:654c4848f0]D 3411 R[/b:654c4848f0].
This same intake valve was also installed on the Model D Unstyled tractor beginning with serial number 109944.
Hope this helps.
Bob...the original 70 diesel head (F1958) had the R57R smaller intake valves. The F3211 and F3511 heads had the larger intake valves. F3211 heads had injector tubes and seals and the F3511 did not. Sounds like you have the best head. Good luck!
Follow up:
Failed Head Gasket:
Below Items were on JD 70 Diesel and Installed back on Tractor:
Head # F3511:
Valves # JD R57R EATON:
Valves # R56R EATON:
Faulty COOLANT THERMOSTAT .....Replaced Coolant Thermostat....Engine was never operating at 180 deg F:
Head checked, matting surface to Block with 12" Machinists level (level has a ground surface) .002 Feller Gauge would not slide between Head and Base of Machinist level:
"Prussian Bluing" applied to Head surface,Contact was evident between face of Head and base of Machinists Level:
Head Torqued 100>175>208 Ft.LBS.
Checked at 208 Ft.LBS several times as per JD SERVICE MANUAL:
Started Engine,ADVISED OWNER to have me Re-Torque Head after Coolant has Reached 180 + deg F :
Advised owner to leave Hood and Grill off so as RAD. can be blocked off to assist in Temp. Rise of Coolant:
Bob..
