The PTO on my 2010 JD works, but does not engage slowly. It acts like an over-camming device. If you engage it, it starts so fast that it will break things and shear pins. Any ideas how I can fix it without a major tear down?
Those are a strange set up,, but I remember that the roll pin hole in the handle would get "egged" out and make this worse,,check that out, we use to drill it out to a bigger pin..
Adding to tim s comment. It's not hard with the right information and tools ( lift/chain fall). You will need to remove the rock-shaft cover to fix the problem. I know you do not want to spend extra money, but an original JD 2010 manual or copy of it, IMHO is a must in this repair. IT manuals leave too much out, like be sure you unbolt the oil supply line to the rock-shaft before removing the cover. You will find it hidden under the cover under the seat.. it's attached under the Rt side of the cover with two 3/8 cap screws.
(quoted from post at 23:24:32 05/21/17) The PTO on my 2010 JD works, but does not engage slowly. It acts like an over-camming device. If you engage it, it starts so fast that it will break things and shear pins. Any ideas how I can fix it without a major tear down?
There is not much you can do with it. The PTO engagement mechanism is one of a kind and is complicated.
The PTO clutch is always engaged, when you start to pull the lever forwards it disengages the clutch and slides a collar on to the drive gear to couple the PTO pack to the PTO Clutch and then it releases the PLTO clutch.
There is a an adjusting screw for the timing of the linkage to engage the PTO. You can access this from the rear of the tractor, but you MUST have a JD service manual to do this.
Send me an email and I will see about sending you the section on the PTO from my JD Service manual.
Even with adjusting the PTO, it is limited what you will achieve. Some grinding is normal and the sudden engagement is also normal.
