John Deere 310 PTO wont move or come out?
Is there anyone that knows how to get the PTO shaft out of a 1961 or 62 310 JD tractor, the PTO wont turn with the PTO engaged or out, it has a couple broken bolts in the rear output. I have looked for a diagram of the PTO but haven't been able to find anything, ANY help would be great thanks. :? :?
If tractor is a 3010 then here's the parts schematic. More than likely pin(key 27) is bent or broken.You could try placing a penny in the center between pto stub shaft(key 3) & speed change shaft(key 15) to push key 15 a little further into tractor. If tractor owner doesn't utilize 1000 rpm pto speed I'll suggest to change pto to 540 only
