JD LI Parts
David G
Where could I find the following front end parts?
AL20149 Spindle bushings and seals
L105T front wheel felt retainer
L106T front wheel felt
Thanks
I got an email into them.
I did find green parts has all but the AL20149 bet they are going to be tough to find
AL20149 is just the number for the complete kit. Don't think you will find it complete anymore. With the exception of the spindle bushings all of those parts are common to an early model M and are still available from Deere or most anywhere else. An M used needle bearings instead of the bushings if you want to do an upgrade. Here are the M numbers as a comparison. Notice the L part numbers.
M 1518T - upper felt seal - 2 used
JD 8820T - needle bearings - 4 used
M 427T - upper thrust - 2 used
L 4629T - lower thrust - 2 used
M 432T - lower seal - 2 used
L 4622T - retaining washer - 2 used
