2030 JD leak at diff lock
Mtractor
I have a 2030 JD that is leaking around the diff lock . I don't see how to remove the handle to get to it. Is there a seal I can change from the out
side?
To R&R o-ring one will need to remove shaft. Rockshaft housing will need to be removed and possibly more parts to gain access.
LOL !!
I had to remove a couple of those shafts before. What a pain in the rear.
Wonder if you could get some brake fluid worked into there by dripping some on the shaft from the outside ? It could help swell up the o-ring ?
