I noticed a significant exhaust leak at the gasket surface between the cylinder head and exhaust manifold of my JD 60 the other day while tedding hay. The tractor runs great but when you put your hand near the manifold you can feel hot air shooting out where the gasket has burnt away. First off, how big of a deal is this? There is some pitting on the upper exterior of the head near the manifold on both sides of the tractor. Will I damage the tractor if I continue to use it for a prolonged period as is? Also, what is the best bet for removing the exhaust and intake manifolds? At a glance it seems I would have to either pull the head and manifold as one unit or disassemble the upper water pipe, fan shaft, carb, etc? Seeking any advice from those who have had to do this before.
Thanks,
Pete
Thanks,
Pete
